Anyone have troubles with Moser 12 bolt axle seals?
Old 04-15-2005, 08:07 AM
WMSuperSport's Avatar
Default Anyone have troubles with Moser 12 bolt axle seals?
I had my Moser 12 bolt rebuilt recently at a reputable shop and they replaced the pass. side axle bearing/seal assy. twice for free and it still leaks very badly. I talked to them again and they said the tubes might be out of round, yeah right. So I call Moser and they say it's impossible and that the shop just didn't install them correctly. I'm going to try a NAPA bearing/seal myself and follow Moser's instructions and see what happens. I was just curious to see if there's anyone out there with some tips or tricks to make this seal work. Thanks,
Wes
WMSuperSport@cs.com
Old 04-15-2005, 09:07 PM
Default ttt...
ttt.......
Old 09-09-2005, 11:15 AM
ttt...
Old 09-09-2005, 03:40 PM
99PontTA's Avatar
try swapping axles side to side and see if the trouble follows the axle?I've had some weird axle seal troubles in the past with different vehicles...some really were a pain to get worked out.
Old 09-09-2005, 04:04 PM
WhiteLTone's Avatar
axle seals, pinion seals, and of course the ring gear teeth falling off.. Moser engineering the leader in hi performance rear ends.
Old 09-13-2005, 11:44 AM
pasbonsimon's Avatar
:raises hand: I am a victim of leaky Moser 12 bolt axel seals- it makes an interesting smoke show on the rotors after slowing from 120+ mph
I need to cut the old bearing off and change the seal- its on my "too do list"
Old 09-14-2005, 09:47 AM
That's funny...I constantly have a "to do list" as well... Right now I have a 2 hour fuel pump replacement going on for months now because of time restrictions...haha. Thanks for the input.
