TA cover, worth it?
TA cover, worth it?
Ordering a new Moser 12bolt next week, should I opt for the TA Cover now and spend the extra $140? How many are just using the regular cover and do you race it a lot? I only plan on going a couple times a year when the weather is good, and probably using ET Streets or MT ET Radials with 5500rpm dumps.
You need the Cover if you go up in size 3.73's 4.10s. the gears do flex so they will hit. Also that cover is very good. You can change the oil and never have to take it off. fill and drain plugs.
Just out of curiousity I was wondering on what gears you plan on running? I just picked up my new to me TA yesterday and it is bone stock. I want to put a set of 4:10's in it but I have heard some bad things about them on here already. Also where is a good place to start looking for a 12 bolt Moser rear. Any help would be greatly appreciated. Thanks
