installed a moser 12 bolt
hey guys just got done with the major part of the install today
its in there but ir was a lil bit of a bitch....
not because on the 12 bolt but the spohn ta was a real bitch hahaha
well first off i got the rear with only a few passes on it for 1500 bucks. its a 33 spline eaton HD posi, 4.10s, 4 channal rear STEAL!!!
i got some used backing plates so i did not have to take apart my rear...it cam with the reluctor rings already on the axles. i put it all togeather and swaped over my brake stuff and today i out her in.
i also picked up some single adj lca and panhard
everything went up fine until time to put up the TA. i had to adjust the panhard and the lcas from there stock langths so i could get the ta to mount up front but not before striping one of the threaded holes for the g-load brace but i drilled it out and put a 3/8 bolt in there hard to do but not to bad.
everything is up not including the sway bar and it looks pretty sweet
cant wait to put my 3.5 alum DS up and conect the lines and throw some tires on and beating the crap out of it
