Tru Trac in a 12 bolt?
Old 04-28-2005, 03:53 PM
RAMPANT's Avatar
Default Tru Trac in a 12 bolt?
Has anyone tried this set up? I see they now have it for the 33 spline axles as well. From what I gather the Tru Trac is durable and is good for the Auto cross/ Road Race crowd and not to bad for the occasional 1/4 mile pass.
I'm putting a 415ci LS2 in my car, I currently have the an Eaton posi in my Moser 12 bolt but I do Autocross and 1/4 mile duty. So any input would be greatly appreciated.
Rampant
Old 04-29-2005, 08:48 AM
BBQLS1's Avatar
It may seem like I'm advertising for Detroit locker(but they do have a solution), they have a 12 bolt locker comming out and have a helical gear posi. Check it out.
Old 04-29-2005, 09:02 AM
RAMPANT's Avatar
Is that not the Tru Trac? I think it is, but could be wrong. That is why I wanted to hear any feed back.
Rampant
Old 04-29-2005, 09:45 AM
z-ya's Avatar
Tru trac is suppose to handle 1000 ft lbs of torgue,I'm waiting for it to show up for
4 series carrier,3 series is out now.Moser now recomends this above the eaton fwiw.
Old 04-29-2005, 11:51 AM
WickEdSix98's Avatar
I've got it and I'm happy with it. Z-ya, are you sure they're still going to produce a 4 series carrier? I was under the impression that they weren't?
Old 04-29-2005, 05:30 PM
Eugenio_SS's Avatar
have it in my 9" and happy.
Old 04-29-2005, 06:55 PM
Warbird's Avatar
My car has an Eaton Posi, I'm very happy with how it held. I just discovered O have a gear swap problem with this carrier unit. I have a 4 series carrier in my Moser with a 3.73 gear, on my current set up I need to step down to a 3.42 gear. The problem is the 3.73 gear is the lowest you can go with this carrier
Anyone want to trade a 4 series for a 3 series Eaton posi?
Old 05-01-2005, 11:32 PM
BlackZCamaro's Avatar
I just finished installing the Moser 12 bolt in my car, and I've 50 miles on the True Trac. So far, it seems pretty smooth around corners. I'll let you know more when I can really get on it.
Old 05-02-2005, 01:47 PM
BBQLS1's Avatar
Rampant
I'm thinking the Tru track is the thing you put in open differentials. That is not what I talked to Detroit Locker about, but a real locker for the 12 bolt that will use a series 3 carrier only.
Old 05-03-2005, 07:57 AM
Hawkcmc's Avatar
True Trac is Trac Tech's new Torsen Style Differential, The open differential replacement parts are called EZ Lockers.
CMC
Old 05-05-2005, 06:29 PM
My84Z's Avatar
Anyone heard anymore on the tru trac? for the 4 series?
Old 05-06-2005, 07:04 AM
BBQLS1's Avatar
Okay, the tru track is the helical gear posi. Just saw an ad for it. The Detroit Locker for the 12 bolt was only planned for a 3 series and they told me no plans for a 4 series carrier, but you can buy a "thicker" 4 series gear that will work with a 3 series carrier. Solution, thick gear and the diff of your choice.
Old 05-08-2005, 02:39 PM
My84Z's Avatar
ok so the 3 won't work with the 4 no matter what??
Old 05-08-2005, 08:16 PM
Hardtop00SS's Avatar
so the 4 series guys can buy thicker gears and run the 3 series tru-trac and not have a problem? Who makes the gears?
Old 05-08-2005, 08:31 PM
BBQLS1's Avatar
Most of the big guys would. The True Trac guys would be able to tell you.
Old 05-08-2005, 09:44 PM
jerflash's Avatar
hey you can get a gear spacer
http://www.jegs.com/cgi-bin/ncommerc...54&prmenbr=361
Old 05-08-2005, 09:49 PM
My84Z's Avatar
I don't mind changeing to a 3:90 I just want to make sure it works and what gears I would need to buy
Old 05-08-2005, 09:50 PM
jerflash's Avatar
where can i pick up a 33 spline trutrac?
Old 05-09-2005, 11:16 AM
00RedWs6's Avatar
I was thinking about going to this Tru Trac. Its suppost to be pretty strong from what I've heard. I wish there was someone who has had it and tried it in a true test i.e. 5500-6000 rpm launches on ET Streets or ET Drags. If it can hold up to that then I'd get it.
Old 05-10-2005, 11:47 PM
Dave_62's Avatar
Well, I have one in my Cutlass. 8.5 axle with 3.73 gears. 5k RPM clutch dumps at the strip with M/T drag radials dead hooking. I could not like the True-Trac more. The car is my daily driver, 15k miles over the past year since the axle install, zero problems. I wish all aftermarket parts worked this well.
