Need a U-joint, which one?
Old 05-08-2005, 08:30 AM
RaNsOm's Avatar
Default Need a U-joint, which one?
Do i need a straight 1350 or 1310/1350 conversion joint?
Old 05-08-2005, 11:44 AM
JMBLOWNWS6's Avatar
Having the same problem yesterday. Call this guy http://www.exoticperformanceplus.com....html?item=145
Old 05-08-2005, 12:29 PM
wrencher
wrencher's Avatar
A conversion joint will work. Call Napa or what ever you should be able to find them.
Old 05-08-2005, 01:54 PM
RaNsOm's Avatar
Ok this is what I do know. The yoke width is 3 5/8". The Universal joint pictured isnt even wide enough to fit a stock 10bolt yoke, so I have no idea what the hell is on there now. The DS caps are the same size as the yoke caps, so Im guessing its 1310/1310. If thats the case then a 1310/1350 conversion joint will work, correct? How do I find out if the DS caps are 1350 as opposed to the yoke caps?
Old 05-09-2005, 12:33 PM
Ls1LikeNoOther's Avatar
that looks like a 1350 i wouldnt put a conversion on it I would get the shaft redone and get a spicer 1350 on it..
Old 05-09-2005, 10:41 PM
RaNsOm's Avatar
I know the yoke is a 1350, thats what I ordered.
Quick Reply: Need a U-joint, which one?
