upgrading gears, what do i need?
Old 05-09-2005, 02:08 AM
borisshnitkin's Avatar
Default upgrading gears, what do i need?
i am going to buy 3.42 gears to upgrade my current 2.73 gears. what do i need exactly to do the upgrade? do i just need the gears or is there more that i have to get when doing the upgrade?
what kind of results will i see with this upgrade?
Old 05-09-2005, 02:17 AM
LT1-Z28's Avatar
I would get a master rebuild kit, and some nice tools, and depending on miles, maybe a new differential... why 3.42 and not 3.73? you should def notice a difference over 2.73...
If you have never done gears, have someone who ahs help... unless you are overly confident like myself
do a search on gear install for the fullsizechevy.com install guide... its a life saver
Old 05-10-2005, 08:27 AM
saturnus's Avatar
I did that swap by my self, 2.73--3.42, and everything turn out very well. No noise and a great diffrent in accelerate. I did that all the way, new Eaton and all bearings.
Old 05-10-2005, 10:05 AM
Kirby's Avatar
How much $$ do you think someone would spend on special tools to do this job. I'm planning on getting 3.73s to replace my 2.73s. I heard install costs a lot so I'm planning on doing it myself. Any certain brand name of gear that you would recommend or stay away from?
Old 05-10-2005, 02:52 PM
14 Second Truck Club
mzoomora's Avatar
If you are upgrading from a 2.73 to a 3.42 or 3.73 you will need either a thick gear(for a 2 series case), a new diff case, or a ring gear spacer(not reccomended). Just upgrade to the Eaton if you have the cash. As far as tools- in/lb torque wrench, dial indicator, magnetic base, a really good impact if you are using a crush sleeve. You really dont need a pinion depth setting tool, you can use a caliper/micrometer to measure your shims and pinion.
Old 05-11-2005, 02:10 AM
saturnus's Avatar
My gears come from GM-Motive, I think they are o`key. Here you can read about
the gear change http://www.fullsizechevy.com/fscu/axletech/
