Dumb Question but which fill hole do you guys use to add fluid
Old 05-14-2005, 06:11 PM
00RedWs6's Avatar
Default Dumb Question but which fill hole do you guys use to add fluid
Im adding fluid to the 12 Bolt but which fill hole do I use? I know this is dumb but do I use the one in the cover at the top or the one on the side? Thanks
Old 05-14-2005, 06:14 PM
Blacker's Avatar
Use the fill hole on the side. Otherwise, you will overfill the differential. You can use the top fill plug and stop fillling once the oil comes out of the side hole.
Old 05-14-2005, 06:23 PM
00RedWs6's Avatar
Default so use the side hole?
so use the side hole and fill it until it comes out the top?
Old 05-14-2005, 06:27 PM
Blacker's Avatar
Other way around. You can use the top hole, in the cover, and fill until it comes out of the side hole.
Old 05-14-2005, 06:29 PM
00RedWs6's Avatar
nm i gotcha
