rebuilding my 10 bolt??
Old 05-16-2005, 02:06 AM
tomss99's Avatar
Default rebuilding my 10 bolt??
my rear just clunked real loud after one pass at the local track.... now when i sit there idling with the windows up you hear some noises coming from the rear.... if i drive in a circle you hear the sucker just clunking around.... would a master install kit and just the ring and pinion gears fix this problem?? or am i gonna need axles and what not... dont plan on getting that 12 bolt anytime soon
Old 05-16-2005, 05:57 AM
WJ SOM SS's Avatar
You better have someone put it up on a lift, pull the rear cover, and evaluate what is broken, or loose inside the rear, preferably someone who is familiar w/the 7.5" 10 bolt.... WJ
Old 05-17-2005, 01:00 AM
tomss99's Avatar
true...
Old 05-18-2005, 04:20 AM
speedo's Avatar
I have a stock 10 for sale if your interested, would be way cheap just to change it out if you do find a problem with the housing
Old 05-18-2005, 12:33 PM
jessedale98's Avatar
How much
Old 05-19-2005, 01:49 AM
speedo's Avatar
Originally Posted by jessedale98
How much
200$ is all.. Ready to bolt in just changed fluid and before I put it away last fall. This year I put my 12 bolt in before I even started it. 38,000 miles on it. Perfect cond.
