*Special* Moser 12-Bolt & 9" Packages
The replacement unit for any broken 10-bolt. Even a bone stock ls1 can break a stock rear, the 12-bolt with eaton posi is the best replacement for the daily driver/weekend racer.
Moser Complete 12-Bolt w/ Eaton Posi
$2135
- Includes 12 Bolt Housing, M/E Custom Alloy Axles, wheel bearings, wheel studs, retainer plates, Eaton Posi (30 spline), Pro Street gears, 1350 series pinion yoke, chrome cover and assembly.
Options:
- Performance TA Cover 160.00
- 4-Channel ABS/TCS Setup 100.00 (Must reuse stock exciter rings & press onto new axles OR have Moser press on new rings)
- 3-Channel ABS Setup 100.00
- Exciter Rings Pressed on Axles 100.00 (4-Channel ABS/TCS users)
- Upgrade to 33 Spline Posi 100.00
* Shipping for 12-Bolts: This unit comes truck freight collect. The trucking company will collect the freight cost at time of delivery. Estimated Costs of truck freight shipping is between $85-150, depending on your area.
Gear Choice: Your 12-Bolt includes your gear ratio choice of: 3.08, 3.42, 3.73, 3.90 ($45.00 Charge for 3.90 Gear Option) 4.11, 4.30, 4.56.
* Add 12-Bolt Installation Kit for $100 (All hardware/fluids needed for installation).
* Note: Additional hardware/fluids will be needed for installation if you do not purchase our kit.
Want the durability of a Moser Full Spool, but don't want to lose additional HP to a 9 inch? Less overall weight and less rotational weight = less parasitic loss (Less drivetrain loss).
Complete Moser 12-Bolt with Full Spool
$1900
- Includes 12 Bolt Housing, M/E Custom Alloy Axles, wheel bearings, wheel studs, retainer plates, Full Spool (30 or 33 spline), Pro Street gears, 1350 series pinion yoke, chrome cover and assembly.
Options:
- No 3-Channel ABS available on spool units.
Want a stronger housing/posi package for higher HP, but streetability?
Moser 9" Auburn Limited-Slip Posi Package
$2255
Includes:
- Housing/Axle Package for F-Body w/ Torque Arm Bracket
- Assembled Center Section - Auburn Posi
- 28 or 31 spline axles
- Gear Ratios: 3.50, 3.70, 3.89, 4.11, 4.30, 4.56
- 1350 series yoke / aluminum pinion support
- JAZ case
Options:
3-Channel ABS Only (Not available on any Ford 9" rearend)
4-Channel ABS & Traction Control: $100
Exciter Rings Pressed On Axles (Required for 4-channel ABS): $100
Aluminum Case (Saves 15 lbs): $155
Add Fill/Drain Plugs: $35 each
Moser 9" Detroit Locker Package
$2290
Includes:
- Assembled Center Section - Detriot Locker
- 28, 31 or 35 spline axles
- JAZ case
Options:
Lightweight Gundrilled Axles (Recommended for only 35+ spline axles): $100
Star Flange (Not recommended for extensive street use): $65
Moser 9" Full Spool Package
$2010
Includes:
- Assembled Center Section - Full Spool
- 31, 33 or 35 spline axles
- JAZ case
Options:
You can give us a call at 973-365-2270 OR place your order online (www.ttperformance.net/shop) and we will adjust the prices on our end. Ignore the shipping charges that the shopping cart program quotes you, we will manually adjust for shipping depending on the unit.
* Shipping for Moser 12-Bolt Rears: Truck freight collect. You pay the shipping company direct, usually runs $85-150 depending on the area.
* Shipping for Ford 9" Rears: Since the Ford 9" comes in various boxes and is not completely assembled (Center section/gears are assembled) this unit arrives via UPS Ground. Shipping charges are generally from $80-140, we can let you know when you provide your zip code.
Note: Since the Moser products are on sale, online order discounts do not apply to these items.
Thanks,
Matt Sorian
$2135
Options:
$1900
Options:
$2255
Includes:
- JAZ case
Options:
$2290
Includes:
- JAZ case
Options:
$2010
Includes:
- JAZ case
Options:
Thanks,
Matt Sorian
