Driveshaft/ U joint
Old 05-30-2005, 07:46 PM
SiL3NtXWS6's Avatar
Default Driveshaft/ U joint
Installing my moser rear end.. I've got a speed inc driveshaft that's shorter than stock for my moser rear. I've got the 1350 option on my rear end. Which u-joint part number do i need to get? I was told napa 448, but some have said 447.
Old 05-31-2005, 12:11 PM
LS1TECH Sponsor
Steve Burger's Avatar
Get a Spicer 1350 U joint. Trust me they are made a lot better.
Old 06-01-2005, 07:06 PM
SiL3NtXWS6's Avatar
the 448 doesn't seem to allow the c-clips to go on.
Where can i get the spicer u joint
Old 06-02-2005, 03:45 PM
SiL3NtXWS6's Avatar
anyone?
Old 06-02-2005, 05:40 PM
LS1TECH Sponsor
SB able to pick up a Spicer or Precision U joint about anywhere. You can order over the net but should not need to.
Old 06-02-2005, 11:00 PM
Kakarot2569's Avatar
you need the napa 447.
Old 06-03-2005, 02:45 AM
SiL3NtXWS6's Avatar
I finally got a u-joint that worked.. however it seems speed inc sent me a driveshaft that was 1 inch longer instead of 1 inch shorter.
Old 06-21-2005, 06:05 PM
Mike94ZLT1's Avatar
Anyone know the part number for a stock driveshaft to a Moser 9" with a 1330 yoke?
Old 06-21-2005, 08:17 PM
00sscam's Avatar
This might help i have installed my 9" and it seams to be 1" longer then the 12 bolt looks like it will fit i will let you know more by the end of the week
Old 06-22-2005, 08:01 AM
Hawkcmc's Avatar
Napa Part #355 I beleive. Ill double check.
CMC
