rearend 3/4 channel Q's
Old 06-01-2005, 12:58 PM
LANDONZ's Avatar
Default rearend 3/4 channel Q's
I currently have a 4 channel with ABS/TCS, im looking at a new rearend for my car but the one I found is a 3 Channel without ABS/TCS. Can I use the parts out of the 3 Channel and fix mine and still have the traction and abs. Basically i just need the carrier and the gears out of it. all the other stuff won't be used.
Old 06-01-2005, 11:09 PM
TRex's Avatar
You would be better off swapping all of your axle hardware into the 3 channel housing, that way you don't need to set up the gears for your housing (assuming they are set up properly in the 3 ch. housing. You can transfer all your backing plates and TCS stuff to the 3 ch rear no problem.
Old 06-02-2005, 02:00 AM
LANDONZ's Avatar
sweet...thats exactly what I wanted to know!!
