BMR Xtreme Duty TA + 12bolt
Old 06-05-2005, 10:56 PM
SSnakekiller's Avatar
Default BMR Xtreme Duty TA + 12bolt
Thinking about doing this TA, but when I did a search I didnt find anything on the noise. Should I just go with an adjustable trans mounted TA or get this? My main concern is road noise. BMR warns of this on their web site.
Is it substantially louder? I dont see what would make this more noisey?
http://www.bmrfabrication.com/instru...bottomview.jpg
Is the trac pak that much better or what? Big power is going behind this but it is a daily driver. I need to know if it is worth it.
Old 06-06-2005, 02:06 AM
Nate_Taufer's Avatar
It says increased road noise because of the bushings. Looks like poly on the body mount and rod ends on the rear. Your car will seem a little more "clunky" is the best way i can describe it. Going over manhole covers and drunk bumps will be audible.
I have rod ended lca's and am not disappointed at all. I am going to do rod ends on all my suspension. I guess it's all about what you can handle.
Nate
Old 06-06-2005, 11:59 AM
LS1TECH Sponsor
Steve Burger's Avatar
I have this setup and it is prone to thunps over large bumps and potholes. Nothing I can't live with. 99% of the time you will not know it's there.
