what do I need(rearend wise) with this setup
Im about to buy a nice procharger setup, my car already has Longtube headers, full exaust system, Lid, and LS6 intake manifold...Im estimateing 425-450 rwhp and match that with rwtq when im done...
Some guys at the shop said "just replace the ring and pinion and your good(3.73 to replace the current 3.42), and keep the 10 bolt"...but a lot of you guys ive head different from...imput would be nice...You guys think I should get a 12 bolt?
oh yea im running on 295/40/18 Kumho tires in the rear
Originally Posted by 00firebird
a higher gear will make you spin more with a procharger... what do you mean by what you 'need'
LS1TECH Sponsor
If you plan to launch hard on sticky tires or DFRs and boost, look into a 12 bolt or 9". That HP level and an M6 can take out a 10 bolt easy. Going to a 3.73 will only make the rear weaker.
you can break the stock diff with stock power if you hook up..... its all a matter of traction not really power youll have a long life on the stocker with shitty tires but with nittos or sticker it wont last long
id do a 9" if money is an issue bu i think the 12 bolt is the best but a 9" would work fine just requires a little modfication i belive and wont have tcs (from what ive read)
With shorter gears they are going to really try to climb out of that housing. Whatever you do stay away from the Richmond gears. Have been through 2 sets, using OE gears now.
