9" or 12 bolt?
I ruin the end of films...
I had a Moser 12-bolt, just switched to a 9". My biggest gripe was that I couldn't run a spool w/ a 3-series carrier. No problems w/ a 35-spline 9" running 3.50s and a spool. 9" will hold a lot more power and can be lightened quite a bit (aluminum center section, lightened gears, drilled and star flanged axles, etc).
There's always Billingsley's 9" setup which is light as hell.
TCS is the same as ur ASR...its traction control. correct me if i am mistaken, but i believe that i have seen some 9" rears out ther now that do have ABS.
Billingsley Racing 9" Street Package
Moser 9" Bolt-In Housing
Assembled Strange Center Section w/ Trach-Tech Locker, 3.50-6.50 Gear, and 1350 Yoke
Moser 31/35 Spline Axles, Bearings, and Studs
Accepts Factory/Aftermarket Brakes & Torque Arm
Perfect Upgrade for High Horsepower and Manual Trans Cars
Assembly Available for a Complete Bolt-in Unit!
Description Part # Price
Billingsley 9" Street Package BR-9SP 2299
Optional 4 Channel ABS/TCS Rings Installed BR-9TCS 199
Optional New GM Brake Backing Plates BR-GMBP 229
With a M6 a 9" with Detroit Soft Locker is bullet proof. I have no problem dumping the clutch at 4,000 rpm's with Mickey Thomson Drag Radials. If you have a strip only car think spool.
