axle install
axle install
it looks like my ring and pinion are fine but my axle is done! How hard is it to install an axle? Or would it be easier to just install a whole new 10bolt? THx guys!
Alxes are easy to install and could get some stronger aftermarket ones to! Just got to get your rotors off take the pin out of the center pin or block pull out of the carrier push the axle in remove the c-clip and slide out then reinstall new bearing and seal slide axle in and put c-clip back on end of axle pull the axle back out till it bottoms out c-clip reinstall center pin or block tighten bolt in pin or block could have either!!! Get a good gasket for cover and fill fluid! On 4 channel traction controled cars ya have to take the sensor off the backing plates if three channel not needed!Good luck!
