rear end going out?
Old 07-05-2005, 03:56 PM
chamillionaire's Avatar
Default rear end going out?
I'm fairly new to ls1s what are some sings that my rear end is going out? since I added headers y pipe and a catback i have noticed like a vibration and I think its coming from the rear end. I it is getting ready to go out what would be a good replacement? its a 98 a4 and im not planning to many mods.
Old 07-05-2005, 05:39 PM
6spdpewterZ's Avatar
be specific. High speeds? Low speeds?
Old 07-05-2005, 07:05 PM
when I floor it at about 20mph and it breaks the tires lose a little some times
Old 07-06-2005, 06:53 PM
anyone have any input
Old 07-06-2005, 10:09 PM
bboyferal's Avatar
If it's just one tire, then you have a problem.
Old 07-06-2005, 11:47 PM
00sscam's Avatar
Yes if you plan on keeping the car please do not ask how to beef up the 10 bolt.
you can't it is like shinning ****.
The board is full of great guys and tons of good info. Read through the chaff and learn what you can.
Welcome to the LS1 world and good luck hope we can help
Old 07-07-2005, 06:39 AM
blue01ta's Avatar
You also may want to check the simple things like make sure all the lug nuts are tight and that your new exhaust system is mounted in tight.
Old 07-07-2005, 07:37 AM
Jake19_2's Avatar
sounds like your tires are going too.
Old 07-07-2005, 12:47 PM
tires are faily new that what the first thing i did back in February. thanks forthe info ill do some more research
Old 07-07-2005, 09:33 PM
Jake19_2's Avatar
I think you would probably hear some whining if it was your rear. If your really concerned you could pull the rear differential cover and check for signs of wear and a lot of metal shavings, of course expect to find some on the magnetic.
Old 07-08-2005, 02:59 AM
black00TA's Avatar
how many miles on your car??
it never hurts to change rear-end fluid.
this vibration noise your describing more like very violent rear-end convulscion?
you might be getting wheel hop now the the added power, and if you have crappy tires that will do it too.
Old 07-08-2005, 08:36 PM
the tires are in good condition it is just one tire its the passenger side, and there is some wheel hop. but there is no whining noise
Old 07-08-2005, 10:32 PM
Jake19_2's Avatar
Some good replacement rearends are the strange and moser rearends. They are not cheap though, around $2500. I am not sure how much a stock replacement would be, but they are not too reliable.
