4 Channel to 3 Channel...
Old 07-19-2005, 04:22 PM
BADSZ28's Avatar
Default 4 Channel to 3 Channel...
Is this possible? What can be done to make a 4 channel rear work in a 3 channel car? Are the sensors the same? Plugs? Can you just plug into one sensor on one of the wheels?
Any help would be great.
Thanks
Old 07-23-2005, 08:14 PM
TRex's Avatar
You need a diff with the abs ring on it and a hole drilled in the housing for the sensor. Not that hard.
Old 07-23-2005, 09:31 PM
Blacker's Avatar
May want to make sure the BCM is the same. The 4 channel systems have two more wires going to the BCM. The BCM may give a fault if it is looking for a signal that is not present.
