Rear axel swap
Rear axel swap
Ihave a 01 camaro. I need a new rear end.It is a v6 auto. My gears r a 342 can i use otheres,or a complete rearend with different gears and what years???I talked to a local garage and they said if i went with other gears they would tear other things up?
I may have the same problem as you. But without the clunky sound. I get a big thump when I smash. I have an auto too, and when my mechanic opened my diff he found shavings as well. I'm guessing it was from all the stupid doughnuts, neutral drops and burnouts I did when I first got the car.. so stupid. Anyhow, what I'm doing is getting a new posi unit and replacing my gears to shorter ones. i've read that my stock 10' bolt can break and I should replace it with a 9'.
If what your problem is the same, maybe you could be doing the same? Let me know what your problem is, when you find it.
I think its normal to find some metal shavings on stuck to the magnet on the cover, just as long as you don't find a crap load, but if its clunking sounds like you do have a problem. I wouldn't think you would need to upgrade to a 9" rear with a v6 auto, unless you plan on some major performance upgrades. The automatics don't put as much strain on the rear as the manuals.
Well i didnt wanna switch to a 9. Ijust wanna swap it out with another 10 and i need to know if i have to use the same gear ratio . Ihave a 342 does it have to be the same or with it mess other things up?
