Can a 3 channel Strange 12 bolt work in a 4 channel car?
If so, what needs to be done? The ABS sensor on the 3 channel rear end is located at the top of the pumpkin as a 4 channel's sensors are located at the axles ends.
The 3 channel 12 Bolt should be able to be adapted to work with the 4 channel system. All you need to do is press on reluctor wheels on the axles and get 4 channel backing plates. I assume you already have the wiring harness/sensors for the 4 channel system? With the 4 channel system, it is either ABS/TCS or none at all. Can't just have ABS in a 4 channel system since they work together.
