Diffrence between...
Old 08-03-2005, 08:29 PM
THE LAST Z's Avatar
Default Diffrence between...
Whats the diffrence between a:
spool
locker
detroit locker
soft locker
all i know is there stronger than a posi and not good on the street/turns. What is your experience w/ any of these on the street?
Thanks.
Old 08-03-2005, 10:00 PM
bigdsz's Avatar
I've got a Detroit soft locker, which is a little quieter than the regular Detroit locker. The soft locker is 31 spline and the regular locker 35 spline. 4,000 rpm clutch dumps = no problem. A spool is a solid connection between the axles and does not lock and unlock around corners. It can be dangerous driven on the streets especially if wet. Some will dispute this.
Old 08-03-2005, 10:38 PM
THE LAST Z's Avatar
So a detroit soft locker will unlock around corners? How quiet is your rear?
Old 08-03-2005, 10:48 PM
bigdsz's Avatar
It locks and unlocks going around corners, but on a straightaway it locks both axles like a ****. It is also relatively quiet ocassionally clicking and clanking.You know you've got a locker. It is solid no give to the drive train.
