ABS with 9 inch
Old 08-05-2005, 08:05 PM
stmz28's Avatar
Default ABS with 9 inch
Can you have a 3 channel abs with a ford 9 inch. If not what do I do with the sensor and will the front abs still work.
Old 08-05-2005, 08:25 PM
SUX2BU's Avatar
nope. go ahead and rip out all of the ABS wiring and block cause none of it is going to work.
i ripped out everytsingle thing involved with the ABS and lost about 30 lbs.
Old 08-05-2005, 11:33 PM
big worm's Avatar
You can have 3 channel abs with a 9" but it takes a little fabrication. Nobody offers it as a kit.
Old 08-06-2005, 07:58 AM
stmz28's Avatar
Is there any way you can make it a 4 channel
Old 08-06-2005, 09:30 AM
35thls1ss19's Avatar
Yea you can get a 9'' with 4 channel.... but who needs abs i have 3 channel and cant wait to get my 9'' and get rid of abs
Old 08-09-2005, 02:41 PM
Hawkcmc's Avatar
ABS is a waste of time just get the 9" and ditch it.
CMC
Old 08-09-2005, 03:29 PM
Carter Hays's Avatar
CMC
I think what people want to know is, has anyone swapped all the components from a 4/channel to a 3/channel car and made it work with the ford rear.
What would be involved ie.. wiring harness, sensors, computer etc.. I don't think I have ever seen or heard about anyone doing this. Can it be done with junk yard stuff without to much work/money? I don't know maybe maybe not.
Old 08-09-2005, 06:01 PM
Avengeance's Avatar
My car doesnt have TCS and Im looking to buy a 9"... but I would like to keep my ABS. I do some traveling with the family... the ABS is "piece of mind" when I have my daughter and wife with me.
If theres an easy way to install TCS at the same time I swap the rear end then Ill do it... if I remember correctly I vaguely remember a harness being behind the spot where the TCS switch goes.. Im wondering if all the cars were wired for TCS from the factory?.?.?.?
Old 08-10-2005, 09:19 AM
Hawkcmc's Avatar
TCS is run through you computer so I dont beleive you can add it after market, or if you could it wouldnt be easy. If you have 4 channel you can get your 9" set up for abs/tcs.
CMC
Old 08-17-2005, 11:37 AM
Z95m6's Avatar
If some of you guys would do a search you'd find i've posted a way to keep ABS on a 3 channel car with a Ford rear end.
Old 08-18-2005, 09:37 AM
Second_Infinity's Avatar
Yes I see that... but does it work really well? Does the signal cut out at all?
(link to the mentioned post) https://ls1tech.com/forums/showthrea...6&page=2&pp=10
Old 08-18-2005, 05:06 PM
00BlackSS's Avatar
there are compaines that sell a 9inch with 3 channel!!!! pm me if u want the site...they are not sponsors!!!
i have 3 channel and am looking at getting this!!
Old 08-19-2005, 06:34 AM
Ric
Ric's Avatar
You've been PM'd!!!
Old 08-19-2005, 09:44 AM
00BlackSS's Avatar
all pms sent back!!!!!
Old 08-22-2005, 06:50 PM
Z95m6's Avatar
Nope i haven't had any problems with mine once i got it adjusted right. LSs1power must of not had his adjusted right. Please pm me a link to that site. I'd like to see this other setup.
Old 08-23-2005, 07:17 AM
WS6WRX's Avatar
I email the guys at the place 00BlackSS recommended and this is the response I got:
Sorry, I have not found a proven method to use a 3 chanel ABS system with an 9". Only the 4 chanel is reusable with a 9" assembly. Scott K.
Which unfortunately is exactly what I expected.
Old 08-31-2005, 10:06 AM
I also received that email back from that company. They do not carry a 3 channel 9".
