Breaking In New Gears?
What's the proper break-in for a new gear set? 3.73's went in today and i was wondering what I needed to do before I could really get on it. Thanks!
Originally Posted by gollum
You can find it here under products, housing-12 bolt www.moserengineering.com The proceedure will be the same for 10 bolt.
M/E Ring & Pinion Gears Break-In Procedure
A new ring and pinon installed with new bearings will initially generate higher than normal operating temperatures. It is advisable to use whichever of the following break-in procedures that matches your application.
Street
1) With car still on jack stands and rear end filled with proper amount of Non-Synthetic lube, run in forward and reverse for approximately 2 to 3 minutes. **
2) Drive vehicle approximately 10 miles at normal operating speed. Accelerate and decelerate several times conservatively, then let cool for one hour.
Drag Racing
2) Pull to line.
Oval Track
2) Run several laps at slow to medium speeds; let cool.
3) Run several hot laps; let cool.
**WARNING: OPERATOR MUST REMAIN IN DRIVER'S SEAT AND ALWAYS MAKE SURE FRONT WHEELS ARE BLOCKED AND JACK STANDS ARE SECURED BEFORE ATTEMPTING THIS PROCEDURE - NEVER EXCEED 2000 RPM WITH WHEELS OFF GROUND. FAILURE TO FOLLOW THIS WARNING COULD RESULT IN SERIOUS DAMAGE, PHYSICAL INJURY, OR DEATH.
Import Patrol
Originally Posted by Wile_E
Here's what it says.......thanks for the link gollum
Street
Drag Racing
2) Pull to line.
Oval Track
Street
Drag Racing
2) Pull to line.
Oval Track
I could not of said it any better myself
