Stock rear end started to whine
Old 08-17-2005, 05:34 PM
JedWele's Avatar
Default Stock rear end started to whine
Today I noticed while driving about 30 to 40 mph my rear end is whining pretty good also any speed under that. I took it out on the hwy and can't really hear it at hwy speeds. I really notice it now while coming to a stop. Any Idea what is causing it? I have a stock 02 z28 .
Old 08-17-2005, 07:57 PM
ULTIMATEORANGESS's Avatar
if its your stock 10 bolt and you race it they tend no to like hard launches.
after my 3.73s were installed they were dead silent.after a few hard launches it makes a slight whining noise.o well.
Old 08-18-2005, 08:33 AM
JedWele's Avatar
Yea I dont' race it, I get on it everyonce in awhile. But this noise went from nothing to very loud. I just took it into the shop to look at it, I will post what they found out.
Old 08-23-2005, 11:56 AM
anLS1x2's Avatar
What did you find out? I have a noise coming from my rearend Sorry couldn't resist. Seriously, the noise I have is from about 10mph +. Is the noise you have a constant Whine, Waaaaaaaaaaaaaaaaaaaaaaaaaaaa or like a Waaa-Waaa-Waaa-Waaa-Waaa-Waaa? Mine is the second one. I'm fearing that it is a bearing but hoping that it is just this common noise that everyone is talking about.
Old 08-24-2005, 08:04 PM
JedWele's Avatar
Yea mine was a constant whine, the bearings went out. I had them replaced. Now that noise is gone but I can now hear a little noise when letting off the throttle at about 30 or 40 mph. I took it back they are saying that it is the bearings breaking in and it can take up to a thousand miles. I don't believe that, but I will put some miles on it and see.
Old 08-26-2005, 07:56 AM
2002z28's Avatar
change the fluid! mine started to whine at 10k miles and i changed the diff fluid and all is good.
justin
Old 08-27-2005, 02:11 PM
-Q-
-Q-'s Avatar
What is a good diff fluid to run? My stocker is starting to whine a little as well and I'd like to get the fluid changed.
Old 08-27-2005, 04:02 PM
JedWele's Avatar
They put fresh fluid in mine when they replaced the bearings.
Old 08-27-2005, 09:59 PM
Shadow Assassin's Avatar
Change your rear geal oil (i.e axle lubricant) and don't forget the limited slip additive and a new gasket to boot. I just get mine from GM dealer. You can change it yourself if you want. It's a pain iin the ***, but only on your virgin try. After that, it becomes old hat. The additive reeks, so don't get it on you.
