Who can build me a 9"?
I am going to be starting on a new project. It will be making a lot of power hopefully on a budget, and will be a FI car so I need a 9". I need someone to build me one with 3:73 gears and should be made to fir a 4th gen T/A.
Check the sponsors, read the feedback. Find one and
Try and use a sponsor that supports the site, but there are a hell of a lot of people, probably in your area that can setup a 9" 3rd member.
Just think YOU might be able to do it yourself..for that full flavored HOT ROD experience.
Last edited by Carter Hays; 09-07-2005 at 10:06 PM. Reason: Do it man!! I know you can
TTP was having a sale. You could either check the eastern section at the bottom or I think it was listed in the gp section too. Where are you from? A lot of times you can just buy the housings, pick up a third member for cheap and have a local speed shop set it up for you. It would probably save you money in the end if you did it like that.
