Tapping Diff/Tranny for Temp Probes
Old 09-25-2005, 03:42 PM
Brody's Avatar
Default Tapping Diff/Tranny for Temp Probes
I recently purchased a SPA diff/tranny temp gauge to keep an eye on my temps at the track. Now I need to install the probes properly to get a good reading but not cause issues. Has anyone done this? Any recommendations?
The more specific the advice, the better.
Here is the probe. Same probe used for both diff and tranny.
Old 09-26-2005, 06:56 PM
J-RODZ's Avatar
What I did was weld a bung on the lower part of the diff cover away from the ring gear.For the trans I drilled and tapped the drain plug in the trans to screw the sensor in.Hope that helps.
