will torque arm work now?
i bought a bmr adjustable torque arm and installed it on my stock 10 bolt using the torque arm relocation bracket to get it off the tailshaft of the tranny. my question is will i still be able to use this torque arm when i install my moser 12 bolt or will i need a new torque arm??? thanks
The biggest problem I have seen is that the 12 bolts shift the torque arm to the drivers side because of the size of the pumpkin, resulting in a significant clearance issue with the driveshaft tunnel, particularly with lowered cars. Does anyone make a bracket that bolts to the pumpkin that shifts the centerline of the T/A relative to the mounting bolt holes ?
