Help!! Where's the drain plug on a Moser???
Old 10-15-2005, 03:13 PM
sdiddy's Avatar
Default Help!! Where's the drain plug on a Moser???
I know the fill plug is on the pass side of the housing...but, do I have to remove the rear cover to drain the fluid?
Old 10-15-2005, 03:21 PM
sdiddy's Avatar
Anyone??? Hoping to get this finished ASAP.
Old 10-15-2005, 04:38 PM
sdiddy's Avatar
Nobody knows? This sucks. Someone has to have a Moser and hopefully be able to tell me.
Old 10-15-2005, 05:03 PM
2001NBMZ28's Avatar
I don't have a Moser, but if it's not in the cover or somewhere low on the diff probably doesn't have one and you need to remove the cover. Someone with a Moser will chime in soon.
Old 10-15-2005, 05:56 PM
chicane's Avatar
There are no drain plugs on the housing. You will have to pull the cover or use a pump to suck out what you can.
Old 10-15-2005, 11:21 PM
sdiddy's Avatar
That's what I thought, but then I was seeing posts saying you needed a 9/16" hex to remove the DRAIN plug on the passenger side of the differential, but the plug they were referring to seemed way too high to be the drain plug (figuring that's the fill plug), so I was unsure. Guess I'll just pop the cover off tomorrow then. Thanks guys!
Old 10-16-2005, 02:09 PM
chicane's Avatar
The side plug is actually the fill. Dont over fill it past that hole too much though.......
Old 10-17-2005, 09:12 AM
sdiddy's Avatar
Chicane: That is what I figured, thanks!
