clunk from rear
clunk from rear
I've had a clunk coming from the rear of the car for sometime now that usually occurs when I shift. I finally had a little time at work today and put her up on the lift to try and find where it is coming from. I've narrowed it down to the rear end or u joints. When I rotate the rear wheels there is a definite clunk coming from that area. I couldn't see any obvious wear to the u joints, but there is definite play somewhere? Possible broken pinion gear, posi, or what?
Originally Posted by J&J Speed Shop
I have seen a good amount that have the worm gears strip partially in the Torsen differential. Which causes a nice bang
