Zexel-Torsen Question
I have a 99 LS1 Camaro M6 Zexel-Torsen rear end currently sitting in my garage. My question is when I rotate one axel the other axel turns in the OPPOSITE direction. Is this normal?? My 93 LT1 axels rotate in the same direction when I have it in the air.
I know that Zexel-Torsen are different than the rear end I have in my 93 because they use gears and not clutch paks, but should the axels rotate in the Opposite direction or is it broken???
