c-clip retainer
Old 02-02-2006, 05:51 PM
2000slpss's Avatar
Default c-clip retainer
i trying to remove my differential but i cant get the retianer for the c clips out. it comes halfway out but hits the gear. is there something im missing? the gears are richmond 4.10's
Old 02-02-2006, 07:41 PM
SScam68's Avatar
Thats odd. Is this the Torsen?
Assuming it is the block or gears should be clearanced for it.
Pics?
Old 02-02-2006, 08:01 PM
TRex's Avatar
You need to take the abs sensors out of the backing plates, then the axle will slide in far enough to get the c-clip out.
Old 02-02-2006, 10:20 PM
2000slpss's Avatar
theres no abs sensors in the rear. the problem is that the block that keeps the axles from sliding in that you remove before you pull the c clips hits the ring gear hwne you try to slide it out heres a picture of it
Attached Thumbnails c-clip retainer-c-clip-retainer-001.jpg   c-clip retainer-c-clip-retainer-002.jpg   c-clip retainer-c-clip-retainer-003.jpg
Old 02-03-2006, 12:19 AM
2000slpss's Avatar
nvm i got it it took some persuading but i got it out
Quick Reply: c-clip retainer
