410 gears and six speed
for the guys with 410 gaers and six speed are ya'll going through the 1/4 mile in 4th or 5th gear. with my 373 im in 4th at around 5500 rpms. but that is with a 2.1 60 ft time and spinning. i am ordering a 12 bolt but i don't want to go with a 410 gear if it will be going through the 1/4 mile in 5th gear.
the popular choice with the 6 speed gear ratio is the 4.10 rear gears...reason being is that in fact you can choose a taller tire to compensate for the ability to turn the tires at will...someone else im sure will back me up...BTW what got your mind set on the 4.10s anyway??
Try out the link on the sticky in this section. I guess its close?
Here is what a 4.10 in 4th with a 245/50/16 tire should run
RPM MPH
6000 112
6100 114
6200 115
6300 117
6400 119
6500 121
same but your 3.73
5500 113
5600 115
5700 117
5800 119
5900 121
RPM MPH
6000 112
6100 114
6200 115
6300 117
6400 119
6500 121
same but your 3.73
5500 113
5600 115
5700 117
5800 119
5900 121
