question about fluid and bearings
I just pulled my 12 bolt axles out because I am putting longer wheels studs in. I figured Id change the rear fluid while im there. IS the royal purple worth the $? How much do I use? Second, I have pressed on bearings and ABS ring pressed on, I took them to a shop to get them pressed off and the studs installed, they said I needed to get a new locker for the bearing and suggest just to do a bearing and locker/keeper. Does anyone know the part # for the bearing and keeper?
