12 bolt ????'s
12 bolt ????'s
Is it possible/feasable to have my brackets cut off of my 10 bolt and and welded on to a 12 bolt. What else would I need. I have the axles, posi, gears already. Thanks.
Yes, but its gonna cost you. It would be better to buy a housing with all that stuff welded on already. The big companies(moser, strange, and currie) have a jig setup that they build them on so there made to factory settings.
Yeah I agree. Plus you will need bearings added to your list. The nice thing about buying a housing from a sponsor is that if you get the stuff welded on by a fab shop and it's wrong they will probably charge you to do it again. A shop has done enough R&D to know where the brackets need to be. If you have all your own stuff or a buddy who would do it for cheap it would probably be worth a try.
