SLP Rear End Kit.....
MarylandSpeed.com had a rear end kit for the 7.5" read end which included 4:10 gear set, Auburn limited slip diff, and install kit. SLP has recently discontinued this and was curious if anybody knew another resaler or wholesaler who has or can get a hold or this kit. Or if not is there another kit comparable to it in price. The list price for this kit was around $550.00. Thanx.....Drive fast and weave alot!!!!
Dont listen to them, if your like me and cant AFFORD a 2k rearend. Then build it up for less, the one thing you must eliminate is wheelhop, lower control arms will do that for you. You will need an auborn hi po. differential. your choice of richmond gear, stud kit, and a rear end girdle. you'll be fine.
Shirley Temple Drinker
Depends, A LOT onthe tranny. If you have a m6 ( good for you ) you may want to look into a 12 bolt if you want to go fast * faster than mid 12's * A 10 bolt is weird. It seems like somepeople can go 10s or better on a4-a3-a2's, and some blow them up with stock a4 or m6 cars...
I personaly wouldn't waste your time and money on a 10 bolt.
