rebuild time
Old 02-21-2006, 12:58 PM
01pewterSS's Avatar
Default rebuild time
i have a moser 12 bolt. going to need it to get rebuilt.
is there a special rear i should get the parts from??
what brand should i get?
also planning on get some 4.30 gears? info on the best gear to get?
Old 02-22-2006, 05:23 AM
EPP
EPP's Avatar
Do you have the eaton posi, or a Truetrak? I'm guessing you have the Eaton, and the clutches need replaced. If so, you might want to consider upgrading to the Truetrak center unit. Gears made by US Gear are quieter than the Richmond gears, and they seem to hold up just as well. us moser vendors don't get much of a break in the part prices, mainly because Moser doesn't build these parts, they purchase them from suppliers. I'd suggest you call Moser at 260 726-6689 to order the parts. Bob
