ford 9inch makes popping noise when i turn real sharp need help
moser 9 inch makes a loud popping noise when i turn sharp the rear end is about 6 months old and it has the detroit tru trac differential and i am sure the noise is coming from the rear end any body know what might be wrong
Restricted User
Have you thought it might be the locking and unlocking of the differential? I'm not a diff expert, but I was thinking the Tru Trac is a "quieter" Detroit Locker, so you still may hear it lock, unlock.
Originally Posted by nutz'00 Z28
I had this same noise turned out to be my LCA bolts where loose and the LCA was hitting the side of the mount on the rearend.
thanks for the info i will check that out. it started doing it when i left the racetrack it was spinning alot. the best i got out of it that day was 10.20 @135 -------------------383 stroker afr 205 heads 11.1 cr. 411 gears 30# injectors 255 lph fuel pump hooker headers magicstick cam electric water pump ls6 intake and ford 9 inch --------490rwhp.466tq nos 630rwhp.666tq
I am having this same problem at the moment and its driving me crazy. Everything is perfect driving straight, but any hard turns and I hear and thump/pop sound.
I will go and look at my LCA's.
Internet Mechanic
Tru Tracs ******* suck, I have 2, and after one wheel hop at the track during the burnout no less, it becomes heir apparent. This diff drives me nuts. Not quite want to drive on a spool but I think a Eaton HD posi for the Moser 12 bolt will go in next.
Like said, when new, the diff felt like it was not even there. I loved it, but as soon as any abuse happens, its fucked. Its non rebuild-able.
Also your unit is a Eaton spec Trutrac. I actually had an original, build dat was back in 2005.
