Looking for some more info before I buy a 9"
ok well i think im ready to buy a rear end. where i am getting it from they ship me the housing and axles and build the 3rd member. i have to assemble it. he said i have to get the abs rings and backing plates pressed on and i wanted to know what needed to be done to assemble it and take some parts off mine please let me know. i will post up with the information once he emails me back.
is there anything else i need to watch out for or purchase? i have an adjustable spohn torque arm that will work wth the 9". do i need anything for the brakes to get them to fit on there? its a moser housing that i will be using.
You will need a NAPA 447 U-joint and the U-clamps to hold it to the new rear. Possibly end links for the rear sway bar cause they break quite often. Buy (2) 3" U style exhaust clamps to mount the sway bar to the rear because the axle tubes on the 9" are a little bigger than the 10 bolts. And while your in there it would be a good time to buy some 5/8" heater hose and eliminate the isolators on the stock coils. If I think of anything else I'll let ya know.
also, why do the endlinks break? i have new ones on there when i upgraded the rear bar.
You lookin for a 9 inch my son just removed one from his car. He's puttin back to stock. Moser 9" with Moser 33 Spline Axles Gun Drilled, Strange Spool Including Brakes and U joints. Interested , let me know.
