Gear whine after install
Old 02-28-2006, 10:26 AM
transam69230's Avatar
Default Gear whine after install
I got richmond 3:73's with all new everything except wheel bearings, and i have an annoying gear whine upon acceleration. It doesn't whine when your coasting but when you give it gas they start to whine. They also whine is certain mph spots. If i drive for a 100 miles and change the rear end fluid, think it would go away?
Old 02-28-2006, 12:34 PM
marv's Avatar
I would assume some wear in noise is possible, but shouldn't last for significant amount of time...
Was the lash set correctly when the rear was set up? Just curious...
Old 02-28-2006, 12:35 PM
jmill96Z's Avatar
M6 or A4? Somestimes using too steep of gears for a carrier will cause a whine. My Richmond 4.10's whined like a little biatch. Richmonds are alot like Ford owners, they whine.
Old 03-01-2006, 03:27 PM
It is an A4 and i didn't install the gears i had someone else do it because i am only a 17 and don't know much about the rears in these cars. I got a serries 2 carrier. Its just annoying but i can deal with it if it gets me into the 12s
Old 03-02-2006, 12:33 AM
CW00BlackTA's Avatar
Probably won't go away. You can live with it or have the installer try to set the gears again. Sometimes it take a couple of tries to get it right.
Old 03-02-2006, 01:20 AM
Juiced2000SS's Avatar
I had Richmond 3.73's in my 3rd gen, whined on either accel or decel, can't remember. From what I've been told Richmond Gears are just noisy. I eventually went to a set of factory 3.42's from a 4th gen and I didn't change a single bearing when I swapped those in only the crush collar and the nut and the noise was gone.
Old 03-02-2006, 01:24 AM
gnbooster87's Avatar
try adding straight LOCUS GEAR OIL, that stuff works miracles, but dont forget the limited slip additive
Old 03-02-2006, 04:52 AM
LETHL_SS's Avatar
Dont even bother with the Lucas... definately wont do much for gear whine <---- tried it and didnt work.
Old 03-02-2006, 07:43 AM
Forza13's Avatar
Get used to it! I have had that same gear, Richmond 3:73, for 4 years and I have changed the gear oil a few times, that noise is there to stay. The straighter the teeth on your ring and pinion the loader the noise. Just put some long tubes w/ no cats and a 3" custom "y" into some Magnaflows you won't hear that little whine anymore.
