Help with moser 9 inch
Old 03-02-2006, 12:11 PM
SPRAYED T/A's Avatar
Default Help with moser 9 inch
I just installed my moser 9 inch in my 01 ws6 m6. it has a detroit locker
with 410's and 35 spline axles. the install went fine exept that now there is
a brutal clunk that is coming directly from the rear end. i put it up on the alignment rack and with the trans in neutral you can spin the drive shaft
about a half turn before the rear end yoke moves. it seems like an insane
amount of back lash. Any one with some ideas would be great about now.
the thing cost me a fortune,thanx alot
Old 03-02-2006, 12:58 PM
LS1Tech Sponsor
Scott@DrivelineSolutions's Avatar
Thats a charateristic of a Detroit locker. By any chance did you recieve the instructions with you assemlby that shows an exploded view of the locker?
Old 03-02-2006, 02:36 PM
JoeyAnderson's Avatar
Sounds awfully familiar to my buddy's install: https://ls1tech.com/forums/gears-axles/442848-moser-9-locker-clunking-like-crazy.html
Looks like that is just the nature of the beast...
Old 03-02-2006, 05:00 PM
Thanx for that link it sounds just like my problem. I really wish the speed shop told
my how bad it was going to be. I drive about 6k a year and it makes the car feel
like a piece. Any one know if tightening the pinion depth would help?
Old 03-02-2006, 05:09 PM
Yes i did get the instruction book with the inside view of the locker.
Old 03-02-2006, 06:06 PM
LS1Tech Sponsor
If you see how the teeth engage then you will understand why the locker has extra backlash. Just make sure no cops are around when testing it out for the first time.
Old 03-02-2006, 10:26 PM
CW00BlackTA's Avatar
You have to get used to it or start thinking TruTrac. I ended up switching since my car is a dd.
Old 03-04-2006, 09:55 AM
LS1TECH Sponsor
badpewter-z's Avatar
nature of the beast you get used to it and thicker oil will quiet it down a little
Old 03-07-2006, 09:19 AM
CTSmechanic's Avatar
I may be wrong but im pretty sure you cant check lash off of driveshaft rotation
Old 03-08-2006, 09:26 AM
78LT383's Avatar
Lockers are pretty harsh but are brutally strong. You can just tell yourself you're a hardcore performance enthusiast (yeah some people just take that approach!) and accept it as part of the price for performance, like loud exhaust, or you can try to get a soft locker. There isn't a lot you can do outside of that. If you're running 35 spline axles, you're pretty much out of luck unless you downgrade to 31 spline which would allow a soft locker or a trutrack.
Old 03-08-2006, 09:34 AM
LS1TECH Sponsor
yup 35 spline , locker DD 3 seasons a year here. you get used to it
