Who's still on stock driveshaft?
Old 03-14-2006, 10:22 AM
BlackLine's Avatar
Default Who's still on stock driveshaft?
I just purchased the S60 from the group buy and stuck on spending about 75 dollars to shorten the stock alum driveshaft or spend around 300 on a steel aftermarket.
after my ls7 clutch install im going to be doing some 5k+ launches and have around 400+ rwhp by midsummer. do you think the stock alum shaft will hold up or should i just purchase a steel one?
Old 03-14-2006, 10:36 AM
JoeyAnderson's Avatar
Your stock aluminum driveshaft will fall over and die if the car hooks a 5000RPM clutch dump.
Get a steel driveshaft, get a loop, and go drag racing.
Old 03-14-2006, 11:53 AM
BlackHawk T/A's Avatar
Old 03-14-2006, 02:43 PM
BlackLine's Avatar
wow, scary.... my budget is pretty tight but what do you suggest for a good lowbudget?
Old 03-14-2006, 08:50 PM
273sunsetZ's Avatar
I'd say, save up your money and do it right. It would suck if you had 400 horsepower, and didn't know when it was going to break. I saw a stock 2000 SS at the track not to long ago, and he had a factory aluminum drive shaft, and street tires. He dumped the clutch at around 3 grand and the drive shaft twisted in two, right off the line. So, in the long run it's better to be safe than sorry.
Old 03-15-2006, 04:00 PM
blueovalbeater's Avatar
Mid 12.58 @ 112 M/T Drag Radials, stock aluminum driveshaft.
Old 03-15-2006, 06:27 PM
BlackLine's Avatar
I found a local shop that said i could reuse the transmission yoke and make a steel shaft for around 175. do you think thats a good deal?
Old 03-15-2006, 08:27 PM
Tally TransAm's Avatar
Old 03-15-2006, 10:18 PM
SPEEDYws6's Avatar
11.55 @ 121 with a soft 3k launch and a a bit of tire spin.
Old 03-16-2006, 12:31 AM
68ss_00ss_87_95's Avatar
i used to do 3k launches w/ 440 hp....no break yet, i still have the stock driveshaft so well see what happens
Old 03-16-2006, 07:11 AM
yak
yak's Avatar
were there two different factory driveshaft options? all of oyurs look nice and mine is all nasty and rusty.
Old 03-16-2006, 08:37 AM
scrmnws6's Avatar
Aluminum does not rust.
Old 03-16-2006, 02:18 PM
BlackLine's Avatar
whats the main difference between steel and chromoly?
Old 03-16-2006, 04:58 PM
Shirley Temple Drinker
Sgt. Spuds's Avatar
weight.
Old 03-16-2006, 05:10 PM
aluminum does not rust but it does oxidize which is essentially rusting...simple green can do that but to rust over time would take a cubic *** ton of years
Old 03-16-2006, 10:28 PM
billazls1's Avatar
Not a bad deal for $175 - I may also check that out at local shops.
