Rear noise / vibration
Old 03-27-2006, 05:13 PM
AW794's Avatar
Default Rear noise / vibration
Ok before i start with my question, i realize that our sotckers suck and that i should buy a 9" or a 12 bolt, BUT i dont have 2200 to spend on a rear end.
What im looking to do is remove the damn noise and vibration. Would you guys suggest a full bearing replacment? The rear has 65k on it. It wont see much track time with sticky tires, so im not to worried about that. I just want the vibration and noise gone. Suggestions appreciated, thanks.
BTW the noise sounds similar to a separated tire, im sure its not the tires. Possibly a bent axle?
and its not the driveshaft....
Old 03-27-2006, 07:15 PM
mvonada's Avatar
If it is that bad, pull the rear cover off and take a quick look,. could be the limited slip going.
