Post up if you are still running the 10 bolt with an auto trans!!
I'm sick of hearing people at the track cry about how they are afraid of breaking weak 10 bolt with their auto transmission car. YES, I know M6 guys can break them easily but I'd like to hear opinions of the 10 bolt behind an auto trans car. Lets hear how you've abused yours! Post up what you do, spray out of the hole, boost, etc!
Personally, I'm not worried about mine at all. 371 RWHP with a PT4000 and 3.42 gears and it doesn't make a hint of noise. I'm looking for a set of REAL slicks so I can get my 60' under 1.75 but i'm still not worried about it breaking.
I know a guy running a lilttle over 400 in his D.D. and hes runnign 10.5-10.7's consistently.(with radials) Ran low 10's with slicks launching at 4000. And he has 3.42's and has never heard a whine.
Broke two teeth off the spider gears on a 1.60 launch with my SS4000. Car lifted the front tires then the left tire got into some water or oil then hooked hard again. That's when it broke. This was on M/T DR's. Found an Auburn Pro Posi for sale here and put that in. Still worried about breaking it though. Once you start getting dead hook traction, the threat of breaking the 10 bolt with a high stall A4 is very real.
I have a friend that was spraying off the line w/ slicks, stall, and a cam, running 10.6 lowest but many many high 10 passes on it, never had an issue with the rear end. He has since totalled the car but he abused the hell out of that thing at the track and it took it.
I know it CAN be done but it usually stems from wheelhop or shocking the drivetrain from spinning then hooking over just raw power.
I'm just curious as to what it takes to break one with an auto trans. I've seen plenty of them live into the 10's on auto cars, i'm just wondering how far into the 10's (or lower) that they'll go.
Originally Posted by gillbot
Did you have a girdle on yours?
I think your right about raw power not breaking it but you never know when a situation like what happened to me will happen. Cars spill **** on the starting line all the time and you don't always see it.
Yeah, I am planning on getting a set here VERY soon. I'm just curious if there is anyone out there that broke it on raw power whether it was sprat, boost or whatever.
Mods
Lid
Filter
Cutout
16' Dr's
Subframe Connectors
Lakewood shocks
150hp wet
Race trans cooler
Race trans pan
3.23 gears
Out of the hole 150 shot netted me 1.8 60fts, after about the 5th pass, started to whine. Never any real problems, just swapped in a new 3.42 rear end.
Lid
Filter
Cutout
16' Dr's
Subframe Connectors
Lakewood shocks
150hp wet
Race trans cooler
Race trans pan
3.23 gears
10 bolt 3.42 gear with a 4k stall th350, hasn't broke yet. I haven't done any big launches at the track with sticky tires yet, since no tracks are prepped around here yet, but no problems on the street so far
im still running my 10 bolt, i ran several times at the track with drag radials and spraying nitrous 415 rwhp 535 trq. That was old setup, i plan on taking it to the track and running it agin with new setup as soon as i put my trans back in car. New set up in sig.
3860 raceweight...best 60' 1.48...best dyno 736rwhp....10 bolt with t/a cover...3.23..torsen and 28x10.5 et drags Busted posi twice wheelhopping during burnout. Broke axle once. Best 1/4 et 9.98@142...best 1/8 et 6.40@112
