any 4th gen with manual steering, no power steering?
Old 04-08-2006, 12:01 PM
trouse40's Avatar
Default any 4th gen with manual steering, no power steering?
im wanting to save some weight and was wondering if there is a kit that converts it from power to manual is it worth it, how much $ i need all the room i can get cause of my t76!
Old 04-08-2006, 12:38 PM
blue01ta's Avatar
Check the drag racing section. I know this gets brought up a lot in there.
Old 04-08-2006, 01:23 PM
GM Muscle's Avatar
You really don't need any kind of kit to convert the stock rack over to a manual set up. Most guys just leave the fluid in it and loop the lines so it can circulate. Madman makes a manual bolt in rack with a different ratio to make steering easier but it isn't cheap.
If your going to run 275s in the front it will be kind of tough daily driving the car, if you are running skinnies it will be no problem at all.
