View Poll Results: How many 10 bolts have you destroyed?
Just my original, now I have a larger one.
12
11.43%
None, still stock 10 bolt.
57
54.29%
1-3 10 bolts.
30
28.57%
4+ 10 bolts.
6
5.71%
Voters: 105. You may not vote on this poll
How many rear ends have you gone through?
Old 04-14-2006, 08:30 PM
LittleSneak1's Avatar
Default How many rear ends have you gone through?
Sorry if this is the wrong area to post in but it seems like the most reasonable being more of a question rather than looking for tech help, and I don't think I've seen any polls similar to this. I hear that the stock 10 bolt rear end is weak in f-bodies and was just actually wondering how many people had problems with it.
P.S I heard of somebody going through 6.
Oh and another P.S if you have blown more than 1 reply with whether it was on the street or at the track, thank you.
Old 04-14-2006, 08:34 PM
camaroextra's Avatar
its not weak by any means. its not good for pulling the front tires off of the ground weekely. when the average person on here says "weaK" they mean they cant put 600hp through it.
iv seen cars run low tens on the stock 10bolt, and iv seen them blow up on a low 12 second car, it just depends how you treat it. what are you plans/mods for your car
Old 04-14-2006, 08:36 PM
Not sure yet I just want to settle that I can do some mild modding, full exhaust, and some tuning then later down the road probably a cam then that'll be it. I don't really plan to take it to the track all the time as well I also don't launch my car/dump the clutch.
The guy who went through 6 I heard was near stock, nothing near 500hp or anything which is why I just wanted to see some general numbers.
Old 04-14-2006, 08:37 PM
yeah youll be just fine. leave it alone
Old 04-14-2006, 08:48 PM
99camarosupersport's Avatar
if it aint broke don't fix it. mods in sig, rocking the 10-bolt.
Old 04-14-2006, 08:49 PM
oh and i've been through quite a few rear ends...there was megan, melissa, amy, suzan......jk
Old 04-14-2006, 08:57 PM
you did meagan too? no ****. When im done with a rear end, there is **** all over the ground with fluid everywhere hahaha
Old 04-14-2006, 09:21 PM
ULTIMATEORANGESS's Avatar
on my third now. it wont last long with my H/C.
Old 04-14-2006, 09:22 PM
Captainofiron's Avatar
I almost went through one. I chewed up my pinion bearing pretty bad trying to show off for some Hottiiiiiees. I did like three doughnuts right after starting the car. Pretty stupid, but thats what girls do to me.
Old 04-14-2006, 10:53 PM
Well anyone here can relate to that.
Old 04-15-2006, 12:48 AM
thunderdan74's Avatar
Mine started leaking fluid at about 50,000. The carrier broke at about 100,000. It saw about 25 passes on the track only with street tires. All I had was a choke master muffler, whisper air lid, granny MAF and HPP3. I never changed the fluid in it Now, I'm on my second 10 bolt. Will she see 150,000? Place your bets!
Old 04-15-2006, 08:50 AM
NXZ
NXZ's Avatar
you should also count 12 bolts. I have been through 2 of those and now I am going to the S60
Old 04-15-2006, 11:25 AM
Orange99Z's Avatar
I replaced my stock rear before it broke with a Moser 12 bolt. That way I could still get some money for it when it was sold.
Old 04-16-2006, 09:42 AM
mcflyz28's Avatar
I still have the stock rear but It's had one broken axle, one fried Posi and three ring and pinion sets, so would that still be considered stock?
Old 04-16-2006, 09:49 AM
Moderator
davered00ss's Avatar
I snapped an Axel on my 98 V6 Camaro, but the SS has put a pounding on my 10 bolt. I did remove the original 3.42 rear and replace it with an SLP Rear end with 4.10's from a friend's car.
Old 04-16-2006, 10:21 AM
91Z28's Avatar
On my third, my last one broke while cruising on the highway. Here is a pic of the pinion, it really fucked the ring gear up good.
Old 04-16-2006, 08:26 PM
1BAD98LS1's Avatar
jus broke my second one yesterday...every single ring gear is completely sheared off
Old 04-17-2006, 04:11 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
Still on mine....1 axle, and bearings were done...now I have a bearing? squeek again from right rear...
Old 04-17-2006, 04:52 PM
98NBMZ's Avatar
Still on the 10 bolt with 3.73s and posi. Guy I bought the car from went some 11.4x on it with a 26" ET Street. Hoping to replace it before it grenades on me.
Old 04-17-2006, 07:51 PM
Ah thanks for all the responses, it was exactly what I was looking for.
