Help with clunk in readens
Old 04-14-2006, 09:49 PM
JGA
JGA's Avatar
Default Help with clunk in rear end
Hi
98 F body A4
Started to get a clunking sound from the rear end when applying light throttle. It only happens under light load in higher gears. In addition, if I tap the throttle on/off it goes clunk, clunk, clunk. It feels tight under power and only happens when crussing at lower rpm. It feels like slack in the driveline.
I have the stock 10 bolt with a bmr torque arm and bmr relocation crossmember. It realy only started to make this sound after I put the torque arm on.
What should I check? Any ideas appreciated.
Thanks JA
Old 04-15-2006, 12:22 PM
zerotosixzero's Avatar
i had that happen to me, a few days ago, then i took my car for a ride, and it sounded like i busted my driveshaft, i pushed the car home, check the driveshaft, it was fine, un joint was fine, poped the rear end over off, MISSING 9 TEETH IN MY RING GEARS!!!!! it was just as you explained, only on a light load, didnt seem to make the sound when to throttle applied, check your gears out
Old 04-15-2006, 08:12 PM
JGA
JGA's Avatar
Hi
Sounds traumatic. If it happens I will call a tow truck. No pushing for me.
If I pull the cover off and find somthing wrong in the differential, it means tearing it down. Also, I have 273s and definately need a 342 or 373. I may as well thrash it until it blows up. I will be rebuilding it in the future anyway.
Thanks JA
Old 05-09-2008, 06:23 PM
Arcolog2's Avatar
This is a really old thread but I recently just had the same clunking problem.
Check the BMR Torque Arm Relocation Crossmember. I found on mine that the BMR Torque arm bushing moves inside the Relocation mount clamp. Kinda shitty since all the parts are from the same company.
Old 05-09-2008, 06:48 PM
twitchtwice's Avatar
mine makes a clunk noise only when i give it full throttle from a stop. any other time its fine. so im going to take the cover off and change the fluids, and hope nothing else is wrong. i just bought this thing ill be pissed.
Old 05-10-2008, 10:27 PM
KENS WS6's Avatar
My rearend was the same, so i ordered a 12 bolt strange.Cant wait.
Old 05-11-2008, 01:22 AM
im just going to ride my stock 10" until it blows up on me, im thinking its okay, i may jsut be paranoid.
