Richmond sportsman noise
Old 04-16-2006, 07:39 PM
Aldertool's Avatar
Default Richmond sportsman noise
question? If lets say pinion depth is .004 (.034 shim)to much, but back lash is ok at .008. Will there be a huge gear noise, these are sportsman 3:42's. Pattern shows the pinion is to far in the mesh on the coast side but its not to horrible and I did correct this by a change to a .030 shim (I will post pics), but my question is, will that much pinion depth cause irregular gear noise even if back lash is right? and can a harder compound gear set cause an osolation from thier mesh? (if that makes sence)
1999 SS camaro 7.5
Old 04-18-2006, 05:07 AM
A502slo's Avatar
come on, u mean none of the gear gods can answer this
Old 04-18-2006, 11:14 AM
LS1Tech Sponsor
Scott@DrivelineSolutions's Avatar
I'm waiting to see your pics so I can give you the right information. What part number did you purchase?
Old 04-18-2006, 11:44 PM
Aldertool's Avatar
the pics were erased from my camera before I got a chance to upload them. I will write back with the part number.
