TA Girdel?
TA Girdel?
Im planniing on buying a TA Girldel soon and i have a couple ? If im not mistaken T preformance is the main producer of them? Second ive looked at a couple and they for money they come with this studded kit what dose it do is it for looks or to make it stocnger? Also when i i take the cover off i expect axel fuild to come out what should i put in what brand should i put in?
Yes, TA Performance makes the TA Gridle.
The stud kit replaces the stock bearing bolts, stronger than stock.
Decent mod to do, it helps strengthen the pumpkin a little, but it's still a 10-bolt.
I have one, I just think it looks nice.
Yes, all the fluid will drain when you pull the cover off.
I would recommend Red Line or Royal Purple 75W90 gear oil.
