getting 9 '' need pics
Old 05-01-2006, 04:59 PM
aw01m6t\a's Avatar
Question getting 9 '' need pics
i'm ordering a 9'' at the end of the week and am having a hard time finding pics of cars with narrowed rears. can't decide how much to narrow. will be running drag radials and skinnies. also wondering if 4.56 would be better for 28'' tall tire. it's a 6 speed. thanks
Old 05-01-2006, 06:04 PM
aw01m6t\a's Avatar
also, I dont plan on mini tubbing in case that helps. thanks again.
Old 05-01-2006, 06:28 PM
SPEEDYws6's Avatar
Narrow 2 inches per side and run a 15x10 wheels with 5.5 BS if you aren't going to mini tub. You will probably find some pics by searching in the drag racing tech forum.
Old 05-02-2006, 04:00 AM
EPP
EPP's Avatar
4.56 gears are pretty steep. How much rwhp and how high are you planning on running the rpm through the traps? Bob
Old 05-02-2006, 06:19 AM
aw01m6t\a's Avatar
Bob, im not sure yet, as i'm planning on doing heads and cam in another couple months. but im aiming for low 11's high 10's.
Old 05-02-2006, 06:44 AM
aw01m6t\a's Avatar
since the 15x10 rims i'm looking at offer a 5'' backspacing will a 2.5 per side work with aftermarket lca's. wouldn't that put the tire in the same position or am i not adding it up right?
Old 05-02-2006, 07:57 AM
SPEEDYws6's Avatar
That should work fine.
Old 05-03-2006, 07:00 PM
aw01m6t\a's Avatar
thanks for the info, speedyws6. i'm ordering the rear tommorow.
