dead spot
Old 05-04-2006, 02:20 PM
BurtReynolds's Avatar
Default dead spot
Will I lose the deadspot of the 2.73 gearing if I go to 3.42
Old 05-04-2006, 10:29 PM
Orange99Z's Avatar
It may help. It will run the car through the RPM range quicker.
Old 05-04-2006, 11:51 PM
MountainMotor's Avatar
Yea, it should help a bit. I had a '95 TA w/ 2.73's and the dead spot was bad but my '98 WS6 has 3.42's and it's not as bad. I'd probably even step on up to 3.73's, if your going for a gear change.
Old 05-05-2006, 12:13 AM
Jassick's Avatar
I believe that stall would kill the dead spot more than the gears, but they should put a noticeable dent in the dead spot.
Old 05-05-2006, 08:59 AM
SLO98Z's Avatar
It's a night and day difference, going from 2.73 to 3.42. It will certainly wake it up.
Old 05-31-2006, 02:29 PM
MyTA99's Avatar
I have headers lid stock stall and tune. What kind of numbers of increase can I expect going from 2.73s to 3.42s?
Old 05-31-2006, 02:45 PM
THE LAST Z's Avatar
The dead spot is caused by the stock(POS) torque converter. It will still be there when you change the gears, but it will get you out of the dead spot quicker.
Old 05-31-2006, 10:25 PM
MyTA99's Avatar
anybody please.
Old 06-01-2006, 01:50 PM
SVT THIS's Avatar
The deadspots will still be there you will just move through them quicker. Get a 3500 stall and you will forget what a deadspot is.
MyTA99 expect 3 tenths to a half second from 2.73s to 3.73s and a whole second or more with a stall of 3500+.
Old 06-01-2006, 09:15 PM
bigman's Avatar
gears wont help that dead spot much, it will still be there, just in a different spot. Getting a stall gets rid of it completely.
