rear end swap
rear end swap
i got a stock rear in my 01 trans am thats a m6. and i want to put the 12 bolt on any one know any sites where they sell the 12 bolt rears with the gears in them. and would i have to change my drive shaft or any thing else?
8 sec potential, 12 sec slip
Just about all the Moser dealers sell the 12-bolts ready to go less fluid. That includes choice of gear ratio, choice of posi/ spool, whatever, choice of ABS or TCS, and many other 'options'. Just look around. Its not hard to find Moser dealers.
Speed Inc
http://www.ls1speed.com/catagory.cfm.../%20Driveshaft
Thunder Racing
http://www.thunderracing.com/catalog...&vid=3&pcid=66
Texas Speed
http://www.texas-speed.com/shop/item...mid=60&catid=6
And to answer your question, No, you don't need a new driveshaft. However its a good idea to upgrade because your stock one won't last long if you put some sticky tires on and get traction with that 12-bolt. But if you do use your stock DS, you'll have to change out the rear u-joint.
Speed Inc
Thunder Racing
Texas Speed
